Administrator
Administrator
Staff member
Jay
Toyota
Official 2025+ 4Runner 6th Gen Specs
Download the full official specs sheet / product info PDF (text searchable) ➡: https://www.4runner6g.com/forum/attachments/2025-4runner-specs-product-info-pdf.5259/
Trim Levels / Models (click on each for specs, features, options, accessories):
  1. SR5 (i-Force)
  2. TRD Sport (i-Force)
  3. TRD Sport Premium (i- Force)
  4. TRD Off-Road (i-Force / i-Force Max Hybrid)
  5. TRD Off-Road Premium (i-Force / i-Force Max Hybrid)
  6. Limited (i-Force / i-Force Max Hybrid)
  7. Platinum (i-Force Max Hybrid)
  8. TRD Pro (i-Force Max Hybrid)
  9. Trailhunter (i-Force Max Hybrid)
Colors:
Engines
  • i-FORCE (Gas Option)
    • Type: 2.4L 4-cylinder Turbocharged, DOHC
    • Fuel System: D-4ST Fuel Injection
    • Displacement: 2,393 cc
    • Horsepower: 278 hp @ 6000 rpm
    • Torque: 317 lb-ft @ 1700 rpm
    • Fuel Economy:
      • 2WD (SR5, Sport, Sport Premium): 20 MPG city / 26 MPG highway / 22 MPG combined
      • 4WD (SR5, Sport, Limited, etc.): 19 MPG city / 25 MPG highway / 21 MPG combined
    • Engine Oil Capacity: 5.9 quarts (with filter)
    • Fuel Tank Capacity / Gas Tank Capacity: 19 gallons
    • Recommended Fuel Type: Regular Fuel / Gas
  • i-FORCE MAX (Hybrid Option)
    • Type: 2.4L 4-cylinder Hybrid Turbocharged, DOHC
    • Horsepower: 326 hp @ 6000 rpm
    • Torque: 465 lb-ft @ 1700 rpm
    • Fuel Economy:
      • 4WD (Off-Road, Limited, TRD Pro, Trailhunter): 23 MPG city / 24 MPG highway / 23 MPG combined
Drivetrain / Transmission
  • Drivetrains:
    • 4x2 (Rear-wheel drive RWD)
    • 4x4 (Part-time or Full-time four-wheel drive 4WD)
  • Transmission Type:
    • 8-speed Automatic Transmission with following gear ratios:
      • 1st gear: 4.41
      • 2nd gear: 2.80
      • 3rd gear: 1.95
      • 4th gear: 1.51
      • 5th gear: 1.27
      • 6th gear: 1.00
      • 7th gear: 0.79
      • 8th gear: 0.65
      • Reverse: 3.64
  • Transfer Case (4x4 models):
    • High/low ratio of 1.00:1 / 2.57:1
  • Final Drive Ratio:
    • 3.583
Vehicle Weight
  • Curb Weight (lbs):
    • Gas Engine (i-Force)
      • 2WD SR5: 4,455 lbs
      • 2WD TRD Sport: 4,610 lbs
      • 2WD Limited: 4,730 lbs
      • 4WD SR5: 4,685 lbs
      • 4WD TRD Sport: 4,850 lbs
      • 4WD TRD Off-Road: 4,850 lbs
      • 4WD Limited: 4,970 lbs
    • Hybrid Engine (i-Force Max)
      • Hybrid TRD Off-Road: 5,225 lbs
      • Hybrid Limited: 5,370 lbs
      • Hybrid Platinum: 5,390 lbs
      • Hybrid TRD Pro: 5,455 lbs
      • Hybrid Trailhunter: 5,500 lbs
  • Gross Vehicle Weight Rating (GVWR) (lbs):
      • 2WD SR5: 6,005 lbs
      • 2WD TRD Sport: 6,020 lbs
      • 2WD Limited: 6,130 lbs
      • 4WD SR5: 6,075 lbs
      • 4WD TRD Sport: 6,395 lbs
      • 4WD Off-Road: 6,240 lbs
      • 4WD Limited: 6,395 lbs
      • Hybrid TRD Off-Road: 6,505 lbs
      • Hybrid Limited: 6,505 lbs
      • Hybrid Platinum: 6,505 lbs
      • Hybrid TRD Pro: 6,505 lbs
      • Hybrid Trailhunter: 6,505 lbs
Exterior Dimensions
  • Wheelbase: 112.2 inches
  • Length: 194.9 inches
  • Width: 77.9 inches (79.9 inches for TRD Pro / Trailhunter)
  • Height:
    • SR5: 72.6 inches
    • Sport, Limited, Platinum: 73.1 inches
    • Off-Road / Off-Road Premium: 73.6 inches
    • TRD Pro / Trailhunter: 74 inches (75.5 in w/ roof rack)
Interior Dimensions
  • Seating Capacity: 5 (7 seats available on i-FORCE SR5 and Limited trims)
  • Interior Space:
    • Shoulder Room (Front/Rear): 58.0 in / 57.8 in
    • Hip Room (Front/Rear): 55.2 in / 56.1 in
    • Headroom (Front/Rear): TBA
    • Legaroom (Front/Rear): TBA
  • Cargo Capacity: N/A (varies by configuration)
Wheels, Tires, Bolt Pattern, Lug Nut Size, Hub Bore:
17" inch dark gray metallic alloy wheels​
TRD Sport (Premium)
20" inch machine finished alloy wheels​
31.5" Yokohama Geolandar A/T G015 Tires (265/55R20)​
TRD Off-Road (Premium)
18" inch machine finished alloy wheels​
32.6" Michelin All-Terrain tires (265/70R18)​
31.5" Dunlop Grandtrek AT20 tires (265/55R20)​
Platinum
20" inch black alloy wheels​
18" inch flat bronze finished alloy wheels​
33" inch Toyo Open Country A/T III All-Terrain tires (265/70R18)​
18" inch flat black finished alloy wheels​
33" Inch Toyo Open Country A/T III All-Terrain tires (265/70R18)​
Bolt Pattern: 6-139.7​
Lug Nut Size: 14x1.5​
Hub Bore: 95.1​
Suspension
  • Front Suspension: Independent double-wishbone with stabilizer bar and twin-tube shock absorbers
  • Rear Suspension: Multi-link with coil springs and outboard-mounted twin-tube shock absorbers
  • Steering:
    • Electronic Power Steering (EPS)
    • 3.25 turns lock-to-lock
    • Turning Radius: 19.7 ft
Ground Clearance, Approach Angle, Departure Angle, Breakover Angle
Off-Road
TRD Pro / Trailhutner
Approach Angle
18 degrees​
18 degrees​
19 degrees​
33 degrees​
Departure Angle
22 degrees​
22 degrees​
24 degrees​
24 degrees​
Breakover Angle
23 degrees​
24 degrees​
24 degrees​
24 degrees​
Ground Clearance
8.1 inches​
8.8 inches​
9.1 inches​
10.1 inches​
Safety Features
  • Toyota Safety Sense 3.0 is standard on all 2025 models and includes:
    • Pre-Collision System with Pedestrian Detection
    • Lane Departure Alert with Steering Assist
    • Full-Speed Range Dynamic Radar Cruise Control
    • Lane Tracing Assist
    • Road Sign Assist
    • Automatic High Beams
    • Proactive Driving Assist
Off-Road Tech / Features
  • Front stabilizer bar disconnect
  • 2wd, part-time 4wd, or full time 4wd
  • Locking rear diff standard on TRD Off-Road, TRD Pro or TrailHunter.
  • MTS (Multi-Terrain Select)
  • Crawl Control
  • Approach Angle: 32 Degrees
  • Departure Angle: 24 Degrees
  • TRD Pro Light Bar
  • Rigid Fog Lights
Production
  • December 2024 start of production for non-hybrid models
  • February 2025 start of production for hybrid models
Pricing
  • See all MSRP base prices & options pricing at: 4runner6g.com/forum/threads/2025-4runner-price-release-msrp-options-pricing-for-all-trim-levels-gas-hybrid-models-6th-gen.1952/
2025 Trim Levels Compared: features, equipment, options
Text searchable PDF version of the chart (PDF download): 2025 toyota 4runner trims comparison - features options exterior chart.pdf
2025 Toyota 4runner Specs: 2025 4Runner 6th Gen trims, models, colors, MPG, dimensions, GVWR weight, towing, clearance, approach / departure / breakover angle ims-comparison-features-options-exterior-chart-
2025 Toyota 4runner Specs: 2025 4Runner 6th Gen trims, models, colors, MPG, dimensions, GVWR weight, towing, clearance, approach / departure / breakover angle ims-comparison-features-options-interior-chart-
2026 4Runner vs. 2025 LAND CRUISER
Specs2025 Toyota 4Runner I-Force Max2024 Toyota Land Cruiser
EngineTurbocharged 2.4-Liter Four-Cylinder HybridTurbocharged 2.4-Liter Four-Cylinder Hybrid
Transmission8-Speed Automatic8-Speed Automatic
DrivetrainPart-Time or Full-Time 4WD With Two-Speed Transfer CasePart-Time or Full-Time 4WD With Two-Speed Transfer Case
Power326 HP / 465 lb-ft326 HP / 465 lb-ft
Towing6,000 Pounds6,000 Pounds
Wheelbase112.2 Inches112.2 Inches
Overall Length194.9 Inches193.8 Inches
Overall Width77.8 Inches77.9 Inches
Overall Height70.8 Inches76.1 Inches
Ground Clearance9.2 Inches8.0 Inches
Approach Angle3231
Departure Angle2422
Breakover AngleTBA25
Fuel Capacity19 gallons17.9 gallons
Old Spice
Bay Area
X3 currently
Thanks for the easy to compare chart. Wish we had 4Runner pricing to throw up there. It's sure to come in lower than Land Cruiser, right?
And vehicle weights should be similar since dimensionally so similar and on same platform?
MJE
Calgary, AB
2022 Ford Bronco Sport
They appear, not surprisingly, incredibly similar. Aside from the height. Is that all a reduction in headroom? Or would you hardly notice & it’d just make it easier for parking garages?
jnsplace
Eastern WA
2016 Subaru Outback 3.6R
LC is full time 4WD though....and yes I'm going to say it. Needs premium fuel. 91 or higher if I recall correctly. Considering the GX is the same, I sure as heck hope that is NOT the case for the 4 runner.
Teebo
Tim
PNW
Highlander / LC250(awaiting delivery)
The Ground Clearance on the First Edition and Premium is 8.7". Considering it's being compared to the TRD version of 4runnuer the chart should probably use the 8.7" number.
pepenachoPER
Jose
Austin
Ford Bronco Everglades
Any idea what is the tank capacity for the LC ?
littlesigh
Dave
Gilbert AZ
2021 GLC300
Great easy comparison! I like the vent shapes on the 4 Runner much better than LC. round seems tired and old style. Interesting the way they have laid out the styles, no more SR5 Premium, now a TRD Sport Premium... Will be interesting stop see the actual listings.
Economisto
Matt
Houston
2000 Mistubishi Montero, 2013 Audi S5
The fact that they both have the same HP and TQ makes me worried the TRD Pro and Trailhunter with the hybrid powertrains will also be premium fuel only. Hoping that is not the case.
Bronconomore
Spud
4 Runner TRD Off Road Premium
I know it is all subjective, but i don't like the raised TOYOTA lettering on the dash, seems like something i would strike my fingers/nails on.
I am sure many will like it though.
jnsplace
Eastern WA
Think the limited didn't have it. I suspect the more aggressive the looks the more the badging perhaps?
I'll use Toyota Jeff's video because he had quite a bit interior. 225 mark. I gotta say, Limited is growing on me. I generally don't care for the classic chrome looks but it's a sweet vehicle.
Markarian421
Earth
2014 FJC TTUE MT
Thanks, I was going to try to look up all these numbers tonight. How about adding approach, departure, and break over angles?
Boobajoob
Platinum
Calgary, AB, Canada
Escape
Growing on me too. This is the model I'm looking at and figure in the future I could black out those name badges and swap the grill as mods start rolling out
