M3P Battery
DFW
George
DFW
Honda
Structures Engineer FedEx
Cyber Truck NMC batteries and NCA batteries are more susceptible to thermal runaway than the M3P battery based on LFP battery chemistry. CT NMC and NCA batteries hit thermal runaway at a lower temperature, increasing the risk of a battery explosion.
Model Y M3P, which would go on sale in 2024.
CATL would start supplying M3P batteries to Tesla in the fourth quarter of 2023 for use in the new Model Y
M3P material compositions
The specific data and composition of the M3P battery have not been disclosed to the public. There are various speculations in the market suggesting that the M3P battery is a lithium manganese iron phosphate (LMFP) battery, but the reality is more than that.
CATL has mentioned in its research that, to be precise, the M3P battery is not LMFP but includes other metallic elements. The company refers to it as a "ternary phosphate system" which has a lower cost compared to ternary batteries but still contributes to a certain cost of new energy vehicles.
The M3P system is based on the olivine structure of lithium iron phosphate as the basic lattice structure. By doping with two types of metallic elements such as magnesium, zinc, aluminum, etc., substitution occurs at certain iron element sites, thereby generating ternary materials of the phosphate system. This improves the charge-discharge capacity and cycling stability.
Why are other metallic elements added? Analysts point out that embedding metal ions in the manganese iron phosphate base can improve charge-discharge capacity and cycling stability. For example, substituting manganese ions with smaller Mg2+ ions can reduce the deformation caused by manganese ions on the overall crystal volume, facilitate lithium ion diffusion, and thereby improve the material's conductivity.
In terms of the manufacturing process, the synthesis of M3P is based on the process of lithium manganese iron phosphate. It is synthesized through high-temperature solid-phase reaction, hydrothermal synthesis, and co-precipitation methods. The manufacturing process is mature and suitable for mass production.
Regarding cost and application prospects, as mentioned by CATL, the M3P battery has a significantly lower cost compared to high-nickel ternary systems. The report also indicates that the M3P material of the phosphate system has broad application prospects in medium and low-end vehicle models.
Cyber Truck with M3P?
Well
Model Y M3P is Tesla's 1st step on M3P road tests.
But
EvBattery technology is advancing so fast who knows where EvBattery will be in 1-2 years .
Maybe
Room Temp Super Conductive power storage with Super Conductive motors will be the next step to completely dumping Fossil Fueled IceCars, IceTrucks, and IceAircraft industry.
