4running
TX
2020 4Runner SR5
Bolt Pattern:
6-139.7 (same as 5th gen)
Lug Nut Size:
14x1.5 (different than 5th gen's 12x1.5)
Hub Bore / Center Bore:
95.1 (different than 5th gen's 106.1)
These figures are from the 2024 Tacoma. I posted it for reference in case anyone searches up this info for aftermarket wheels, lugs studs, etc. (or for fitting 5th gen 4Runner wheels).
Since the 2024 Tacoma 4th gen and 2025 4Runner 6th gen are essentially identically mechanically. We should expect that their wheels related specs will be the same.
Old Spice
Bay Area
X3 currently
Looks like 5th gen 4Runner factory OEM wheels won't be a swap option for the 6th gen then.
Nuke
Platinum
Jim
Rexburg, ID
2021 Highlander Platinum
I wonder if this will hold true for the Tacoma? However, the previous generation Taco is a lot closer to the new than the previous 4Runner is to the new generation. The new 4Runner is essentially a Tacoma with a different body, reverting back in this regard to when the 4Runner was just hatched.
TheBat
2010 4Runner Trail, 2022 GR86
Not a perfect fit but I just checked my OEM 5th gen 4Runner 17" wheels in the garage and a 14mm stud will fit no problem. You can use rings to fill the gap on the hub (assuming that they are hub centric), lots of aftermarket wheels require them, but some guys don't like them.
Nodak
Platinum
JR
ND
2014 4Runner
Bolt Pattern:
Lug Nut Size:
is this the same specs as the 3rd gen tundra?
i have a full 23 tundra set in grey that i want to use to replace the platinum gloss black wheels with.
also the new 25 4R has a 8 JJ width compared to the old 8.5/9.0 JJ spec i think
Skiddy
Seminole Florida
Toyota Tundra Toyota Rav4 Toyota 4runner
Method sent me the wrong lug nuts and the wrong center bore hub rings. They are sending me another set of lugs but they seem to think the rings wont be an issue since they are "lug centric" wheels.
Shawn_1121
TRD Sport Premium
Shawn
Hudson, NH
25 Sport Premium
What came of this? Been looking at method wheels but they're hub bores of 106.25 not the right size for our 4runners 95.1
Skiddy
Seminole Florida
The Method experience unfortunately was pretty bad. The lugs were finally replaced and when I told them the Hub bores were the wrong size they said it didn't matter and never sent the replacements . I purchased my own. When the shop went to install them they found one of the wheels was missing the center cap. Called Method and they sent the wrong size replacement. Took two weeks to get the proper size center cap. The wheel cleaner we ordered leaked in the box and they had to send another.
On top of all their mistakes we had issues getting the wheels balanced.
I wont be using Method in the future.
Shawn_1121
TRD Sport Premium
Shawn
Hudson, NH
25 Sport Premium
that sucks all around. I've been a Black Rhino guy for years, Thought about changing it up for the 4runner but it seems to not be the way to go. thanks for the reply
alpa_chino
Deep in the heart of, Texas
TRD ORP i-FORCE MAX
Bolt Pattern:
Lug Nut Size:
Whats the correct torque for the lug nuts by chance? Taking notes before mine arrives. Thanks for all the great info
Nodak
Platinum
JR
ND
2014 4Runner
i am going to go out on a limb, but looking at the specs for 25 tundra, sequoia and tacoma, they all use the same wheel specs so i am guessing the 4runner will use the same specs including wheel torque of 131 nm
the left block is the 25 sequoia, the middle is the 25 tacaom, and right side is the 25 tundra
2025 Toyota 4runner Bolt Pattern, Lug Nut Size, Hub Bore / Center Bore (6th Gen 4Runner 2025+) torque specs
Xhale760
Kris
San DIego
2025 4Runner
Does anyone know the correct part number for the matt black lug nuts? Looks like i ordered the previous gen ones.
spyder40
Indiana
2021 4Runner ORP
Anyone with firsthand experience putting 5th gen TRD Pro wheels on their 6th gen and any issues? Don't want to deal with the rings but I do like my wheels better than the new ones
JR1
TRD Sport Premium
Missouri
2008 SR5 2025 TRD Sport premium
If the bore is different I don’t think you have a choice. You have to use the rings. I sold my 24 Pro last year preparing for the 25’s. I know for sure that the bore is different.
Xhale760
Kris
San DIego
2025 4Runner
If you want just black lug nuts, the best way to get them price wise is to order 5 of part# PT076-0C200-02. If you want lugs and locks, you will order 4 of part# PT076-0C200-02 and 1 of part# PT276-34231-02.
Got this information from my dealer I ordered rims from
