bml42
TRD Sport Premium
Brian
Connecticut
2024 Tacoma TRD Sport Premium (6MT) in WCP
Lol it doesnt.
So every single item in the above list is wrong?
Also, there are now how many numbers listed for a roof rack?
$2,225 in the above sheet, $1,1199 at the below link, $1,425 in your screenshot... Thats even ignoring the $800 in your image for assembly
https://www.tacoma4g.com/forum/threads/2024-tacoma-post-production-options-ppo-guide-oem-trd-accessories-parts-pricing-updated
You dont find that incorrect or confusing? Should I pick another item? Why is the cargo net $49 on one and $45 on the other? The bedstep? $385 on one and $455 on the other.
I will give you my understanding - the PPO is Post Production, which I presume might be the total cost to get it and have it installed. The DIO is dealer installed, and specifically says Parts Only, which means the dealer will then hit you with a separate labor cost to install whatever part it is.
So the TRD 18ā€ black wheels are 300 a piece MSRP, parts only, for DIO or Dealer Installed. The same four wheels are 1325 MSRP on the PPO list, which is the same cost at build time so I think that’s an installed cost.
Anyone that knows for certain can correct me if I’ve got it wrong. Plus, I don’t have my 2024 yet and took delivery of my 2021 the way it became available at the dealer, so I have no direct experience.
zachavm
Zach
Oklahoma City
Subaru Forester & Subaru Ascent
Me considering installing Onboard Tire Inflator (Air Compressor) on a Limited/TRD Off-Road:
2024 Tacoma 2024 Tacoma Dealer Installed Options (DIO) Accessories Parts Guide + Pricing (Updated 5/7/24) giphy
Salt Lake Valley, UT
2024 Tacoma SR5, 2004 4Runner SR5, 2001 E55 AMG
TRD center pipe is required to install the trd exhaust? Am I seeing that correctly? If that’s so then this is the only place where that is mentioned. Wish I would have known that before I ordered šŸ˜…šŸ„¹
Baltimore
Maryland
4g hybrid
Much of this is repeated prior, but thought I would drop it in from the web hunting and phone calls I've been making, either because I have sourced it, or considered sourcing it.
AccessoryConfirmed Part Number
Toyota Molle Panel Kit (declared incompatible with spray in liner)PT767-35700/800/900
Toyota Bed Mat - Short Bed (declared incompatible with spray in liner)PT318-35240-02
Toyota Molle Cargo DividerPT767-35240
Ball MountPT22835246
Tow Hitch Ball 2"PT79100844
Tow Hitch Receiver PlugPT22835960HP
Spare Tire LockPT27634071
Bed CleatsPT27835160
Bed Tie-Downs (Mini) w/HooksPT27800160
First Aid KitPT42000220
BedStepPT39235920
Tacoma Off-Road Trail PipePT226-35241-AA
Black Badge Inserts/OverlaysPT948-35243-02
Black Tailgate InsertPT948-35241-02
Color keyed outside mirror caps [G0 is Bronze Oxide color code]87915-AK030-## & 87945-AK030-## [RH, LH]
Driver side storage casePT944-35242/52
Driver side storage case (Replacement Part?)PT944-35250
Alloy Wheel Lock PouchPT276-34190
TRD 18-In. Flat Black Alloy Wheel (18x8, 6x139.7, 45mm offset, 95.1mm bore)PTR56-35242-F1
Wheel Center Cap - TRD Pro Flat Black/RedPT280-34221-2F
Alloy Wheel Locks - BlackPT276-34231-02
Hub Nut with Washer (Alloy Lug Nuts - Flat Black)90942-A1008
BRONZE Trailhunter Wheel: Flat Bronze (18x18.5, 6x139.7x 20mm offset, 95.1mm bore)PTR56-35240-5F
BRONZE Trailhunter Wheel Cap: Heritage flat Black/BronzePT280-35221-5F
Tacoma Low Profile Roof Rack (Full Kit)PT767-35100
Tacoma Low Profile Roof Rack (Replacement Parts)PT767-35100-RK
